sbsyncro
I have a small trailer that I use for off-grid camping (a Turtleback Getaway). It came with a Zamp PWM charge controller and Trojan Group 31 AGM battery back in 2018. The battery just finally stopped holding a charge and I can't bring it back to life. I want to switch to a pair of LiFePO 100ah batteries (to effectively triple or quadruple my reserve power). For charging, I use either a 220w folding panel that has an open circuit voltage of 57.6v (if there is no wind and I have space) or if it is windy or have less available space, I use a rigid "suitcase" type 120w panel with Voc of 23.4v. (I also have a NOCO AC-DC charger for "shore power" charging as well as a direct feed via the 7-pin connection for ~2 amp DC-DC charging while driving.)
Based on my research and reading up on specs, etc. it seems like the Victron SmartSolar MPPT 75/10 would meet my requirements, but I want to make sure I'm not missing something. It has a max voltage input of 75v, but I'm confused by the spec that says
"Nominal PV power, 12 V 1a,b): 145 W. (1a) If more PV power is connected, the controller will limit input power.)"
Does this just mean that if the panel is operating at 12v output then the max panel output that can be accepted is 145 watts (12.08 amps)? (in other words, I don't need to worry about it because my 220 watt panel operates at 48v/4.58 amps, so well within the 10 amp spec for this controller?
I want to make sure I'm not under-sizing this controller. I also am not sure about whether I need to introduce a DC-DC controller to this scenario or whether the Jeep's charging regulator as an input to this controller will work. (Again it is not a "serious" DC-DC connection - just the stock trailer wiring harness which limits the charging current to about 2 amps)
Thanks in advance for the advice!
