gr8pix
Hello, confusion again about wiring connecting 2x 24v 200AH batteries in parallel. I recently decided to add another 200AH 24v battery and am confused about the fusing requirements and would be grateful for any suggestions. Originally with one battery I had a 225A class T in between the battery and the Lynx distributor. In parallel, should I be fusing the positive terminals on the batteries and then connecting to a bus bar, and then fusing the bus bar to the Lynx with another higher rated class T? The MRBF would be 225A on each battery and the Class T 400A in between the bus bar and the Lynx? I'll be up-sizing all the 2/0 wire to 4/0 as well.
