I'm just getting started with solar and learning what I can so excuse the simple question. I have one of these U27-12xp batteries on my travel trailer being fed by a 100W panel (which I plan to expand).
The question is, am I OK using this single battery without the external BMS? What if I add a 2nd parallel? If I'm not, would that Thunderstruck BMS be sufficient for my needs?
No you won't be okay without a BMS. And yes the thunderstruck BMS would be sufficient for a single battery or any number in parallel but you need to make sure you have a contactor hooked to it so that the BMS can disconnect your battery in case you accidentally try and over discharge the batteries. over discharging is particularly easy in an RV because it uses 12 volts for all kinds of stuff. not like a traditional person would have an inverter hooked to the battery and the inverter would shut down when the battery got low. And make sure you have a charge controller between the panels and the battery. Search this website for valence super thread. It has lots of information
Thank you for your advice.
