JCSchwarb
- Nov 26, 2022
- 499
All-
I reposted this as separate topic to focus on common neutral used across two split phase inverters.
Appreciate the community experts help on my EG4 6400 6 Inverter Installation. My inverters are wired to Grid Input, PV array, and EG4 batteries. I used a three wire 4 Ga with ground to supply 3 sets of split phase, total of 6 inverters. A common neutral has been split between each matched inverter pair L1/black, L2/red with shared 4ga neutral for grid input and a common neutral matched pair with L1/black and L2/red with shared neutral split between the output. While multi branch is permissible in this type of installation, is there anything about the EG4’s that may cause ill effects? Each black/red pair terminate in a single 60amp double pole, per NEC. Signature pointed me to the manual, but do not see multi-branch common neutral as an issue on a split phase configuration. While this was not my preference in wiring, I followed this approach due to no single strand THHN in my area for that gauge wiring. In retrospect, I learned a hard lesson in complexity and possible future faults with so many wiring connections and added cost of Polaris connectors.
Thanks in advance to help me understand if EG4 or other inverters in split-phase can use common multi branch neutral sharing assuming NEC compliance.
-Jay
-Jay
