i bougth this from https://www.amazon.com/ZOOKOTO-12V-...s=150a+breaker+24v&qid=1596642919&sr=8-3&th=1 and it get hot when i use about 2000W keep using it for 20 minutes.it tripped. any recommendation for a better one? thank you
That style breaker really should not be built for more than 150-200 amps.
For giggles I bought a few of those off ebay and tested them. If they could be called anything, apart from junk, they'd be 80A but there was so much variance between each one that even that would be pressing it. There are plenty of other reasons why they shouldn't be used too, no arc trap, housing is flammable, and it's not sealed either. At least the one in the opening post doesn't have Ignition Protected written on it, which is the final insult you see when looking at it as your premises burns down.That style breaker really should not be built for more than 150-200 amps.
The only 2 manufacturers I trust are littelfuse and bussman.
Bluesea rebrands bussman so those are good as well.
BTW: Eaton is another reputable breaker company and their breakers of that style also top out at 200A.
Adding to what others have said, circuit protection is a great place to avoid buying the cheap no-name amazon/ebay/aliexpress components, and buying from reputable companies with a track record.
Best I can tell Eaton = Cooper = Bussmann = Buss. Or at least all these brands are affiliated in some capacity. I have the vague impression Cooper and Bussmann are sub brands of Eaton. Then their is Blue Sea which rebrands them under their own brand name.
I just realized that we never answered the OPs request for a recommended alternative. Unfortunately, I am not aware of a good 300A breaker. Midnight solar makes some big 'main' DC breakers but 1) they top out at 250A 2) they are expensive and 3) they require a box to mount them in.
I used to have an attitude that breakers are the only way to go. I wanted to be able to reset the breaker, no matter what. However after I tried researching high current breakers, and then thought about it a while, I no longer think that way. The only reason to mandate a breaker instead of a fuse is if you think there is a reasonably good chance the overload protection will trip during normal use. If a design is going to blow a 300A circuit in normal operation....that design needs to be changed. The only time a 300A circuit should blow is in an extreme catastrophic condition. At that point, changing a fuse is the least of your worries.
BTW: all of my BMS's have over-current protect so they will almost always shut off before a breaker would anyway.
So.... for a 300A circuit, I would put in a fuse and have a spare on hand. (Yes, I fuse my battery even if the BMS also has over-current protect). Even at 200A DC I use a fuse instead of a breaker (breakers are much more likely to fail than a fuse. ) I generally don't consider using a breaker for anything over ~150A.
If there were quality high current breakers available at a reasonable price, I might use them. However, I can not find such a beast. If you find one, let us know.
You can do that, but make sure your wiring is all sized for 200A. (You don't want your wires to burn before fuse blows).my system only max out at 120A. I just double the amp. 200A is enough.
4AWG is only rated for 100A. That is too small for what you are describing.All wires are 4awg
Sorry where am I to look?The interesting thing is that if you look at the chart just below that, they show 4AWG topping out at 100A...
