I'm going to upgrade to a Victron 100/50 SCC with the Global Link 4G LTE. My setup is a remote off grid hunt camp. Built a 4s12v 200ah lifepo4 installed in an insulated heated case. My insulation consists of a layer of thermal foil bubble wrap exterior with 1.5 inch rigid foam inside of that. I had to move the bms Bluetooth dongle from inside to outside of the insulated cocoon but still within the case. I guess the layer of foil wrap was blocking it's signal or greatly hampering it. Because of my setup the Victron SCC manual suggests a smart sense battery temperature and voltage monitor. The instructions say attach it to the side of the battery, but I worry it's Bluetooth range may be affected by the layer of thermal foil. The Victron SCC and the battery will be only about 3 feet apart. Anyone have such a setup or any advice would be greatly appreciated.
