Need help on setting up 1st solar system
Mrats
Thank you for reading this. I am setting up my 1st solar system.
1. My lifepo4 battery 150ah with 150a bms, running for inverter 1500w, also added a 150a fuse between inverter and battery. Above setting is ok?
2. My MPPT controller only able to handle 7 type battery (as attached photo). Is this MPPT controller able to charge lifepo4 battery?
Thank you so much for all of you
What voltage are you running at? That's the missing piece of info to determine if your fuse is sized correctly. Looks like a "NO" on the MPPT, but if you state the brand and model, that might help.
Sorry for missing information, whole system is 12v. Both solar panel and battery / inverter.
Inverter : it is inverter with MPPT controller. One-solar as attached
Thank you
That charger is not suitable . If Equalisation can be turned off and the voltage kept below 14.2 V at all times it might be used for a time. You would need to really look closely at the charger section of the inverter. On some chargers the GEL setting is as close as you will get.
