This question is not directly linked to this forum. But I hope someone will be able to help me with this
I have an off-grid system with SRNE inverter. I have set up Home Assistant & get the inverter data to it through ESPhome via ESP32. There are some read / write modbus registry entries eg. inverter to grid switching voltage. I can read the value in the inverter easily as follows
I want to edit this value directly through the Home Assistant interface without physically adjusting it through the inverter itself. This should be possible since this is a read / write modbus registry entry. I don't have any knowledge of coding for this.
Can someone please help me to make this work?
- platform: modbus_controller
modbus_controller_id: srne1
name: "Inverter Switching Voltage"
register_type: holding
address: 0xE022
unit_of_measurement: "V"
accuracy_decimals: 2
device_class: Voltage
state_class: measurement
