I need a sanity check here, I have 3 EG4 LL V2 batteries, right now I have the RS485 port from the master (ID2) to SA and it's showing status. I am trying to get the other 2 connected with the USB hub method and I'm not having any luck.
I can wire up a USB to RS485 dongle identical to this one supplied by Signature Solar (white\orange and orange wires to + and -) and I can use this cable in place of the cable provided by Signature Solar with no issue, however if I move this cable to another battery it shows BMS communication failure in SA. If I change the battery ID to 2 on that other battery then I can connect.
If I change all 3 batteries to ID2, and I remove the batt comm cables between them, I can connect to any of the 3 with this cable.
But, how do I combine them in SA? They show up as 3 distinct USB serial ports in the dropdown picker, but unlike the Inverter selection I cannot choose more than 1 at a time. Each works independently (as long as ID is 2) but I can't combine them... I've tried 2 different USB hubs (like this) as well.
I even tried wiring 2 cables to a single dongle, connecting the wires, no luck...
