S610
Bought a wooded lot -- how do I estimate the amount of trees that need to be cleared for optimal sunlight? Lot is flat and located in Arkansas (the Ozarks) if that matters. The panels will be ground mounted.
Is there a calculator of some sort? I don't want to remove more trees than is necessary. Should also mention a general contractor will be clearing the lot so this isn't something I can do myself in "steps", it needs to be figured out before they begin.
