Hi everyone, first post here.
I'm setting up my solar and I'm torn on inverter orientation. Option 1 has short battery cables but ac block is facing me, and display is upside down on inverter. Option 2 (shown in pic), i need an extra 18" of cable from bus bar, but ac block is facing the back (thus sorta hidden), and display is right side up. I have kids so I want this as safe as possible and prefer option 2.
Question: to considerably shorten the cable length to inverter, can I connect two legs on the main fuse and shunt? These two will be attached to the battery box which will be secured in place.
positive: battery + > on/off switch > fuse > one to + busbar and one to inverter
negative: shunt load side > one to - busbar and one to inverter.
I'm using 2/0 gauge cable for my battery/inverter which is excessively big for my setup but all I could find so settled for it. This would allow me to use longer cables.
Note: board needs to be cut so I can stick it to side wall and angled portion in the back, there will be a lot more space than it looks in photo.
Also building a wood base so I can properly secure battery and inverter and limit holes on countertop.
Thanks!
Thanks!
