Hi all, been hanging around here and other places for sometime now. I hope this is not to long.
I have a 1 1/2 car garage with and unfinished area above, few wall but all open.
It has a 1 1/2 hp door opener and other than that there are a few lights that will all be LED, and an outlet or two mainly for charging batteries for the tools, and possibly a small dorm type fridge . These are the current needs, there are other things i'm sure will be added but that is sometime down the road, year or more.
Local power company wants $1100.00 to run the power and I need to cover the mast and the wire from the mast head inside. That is right at my current budget, but why? and then pay a bill wether I use any electricity or not.
So here's my plan, using renogy
I have and excellent clear view of the southern sky year round and plan the mount the panels on the front of the garage with an adjustable angle, and ground the whole system. I'm sure I have forgotten some things but any thoughts? Should I scrap this and start over?
Renogy 400 Watt 12 Volt Premium 4 Pcs 100W Panel+40A MPPT Charge Controller+ Bluetooth Module Fuse+ Mounting Z Brackets+Adaptor Kit +Tray Cables Set, 400W, Grid 12V Solar Power System
and addingRenogy 3000W Pure Sine Wave Inverter 12V DC to 120V
I know that most here use and reccomend lifepo4 batteries but the are out of my range now, so i'm planning to use AGM, 4 100ah batteries. also there is a new 200amp square D breaker panel and i'm going to wire it into that .
