fromport
Do you want me to break warranty before even powering it up ?Can you open the top part of the inverter and take some pictures of the insides? I would like to see the motherboard and the inductors, etc.
Yea I understand that to parallel them you need the CANBus cable not WiFi. The inverters don't use WiFi to communicate for paralleling. But I believe from the manual that the inverters must be told they are in a group. You have to terminate them properly as well.I bet you the configuration might be way easier to do using app/desktop.
But the parallel communication between the (up to 10) inverters in parallel would be way to uncertain if you would use WIFI.
I highlighted in purple the CANBUS cables for inter-inverter communication here:
SureDo you want me to break warranty before even powering it up ?![]()
Are you going to use these as pass through or to simply feed your home grid??? If you have two of them and need a battery anyway wouldn't it be easier and maybe more economical without needing a bunch of disconnects etc to simply use the battery to enable grid down back up vs using pass through option????Nick told that they have about 100 inverters in stock ready to ship. I had asked Nick, if I would be getting two inverters from the new production run with the GSL logo, color, latest firmware, etc. The answer was no and he sent me some photos of the inverter in stock, which are white and black with the GSL logo, which is the brand name. He asked me if that was okay. I told him okay, that it was only a personal preference for the GSL inverter to match the GSL batteries. I will be getting the same inverter that the other DIY members have received.
Time for a fiber optic camera.View attachment 117313
Screw under there
Thanks for the images! I will anxiously await your other messages as you get further along.That is it for today
Tired, cold & dark outside now ;-)
Definitely transformer-less. Looks like they are using the case as a heat sink. Is the case cast aluminum?This is the overview photo, probably not as important that it is out of focus
I'd also like to know the idle consumption on these.When enough people get these, I hope someone can do some load testing on them. I want to know how well they handle unbalanced loads, heavy start up loads and how hot they get under full load. Hopefully someone with an oscilloscope can show us the sine wave under full load.
I appreciate the comment and the suggestion. I have read it over and over several times, but can't visualize your suggestion. What you are saying is probably something that I should consider, but I just don't understand the concept. The description below should give you an overview of what I'm trying to do. So maybe seeing my situation, you will know, if your suggestion is applicable for me or not.Are you going to use these as pass through or to simply feed your home grid??? If you have two of them and need a battery anyway wouldn't it be easier and maybe more economical without needing a bunch of disconnects etc to simply use the battery to enable grid down back up vs using pass through option????
I sent the photos that GSL provided me showing these hybrid inverters laying on tables as you described 'UNBRANDED.""Case is steel (magnetic)
Could you let me know which firmware yours came with? My case is completely unbranded. I’m wondering if there are any differences, firmware or otherwise.
Just a note..............I got my LuxPower 12kw inverter from GSL in China in 2 days via air. Two days is still a big deal, but if something fails, they CAN and will get it to you quicker.I've had $35000 heart monitors fail on me when I needed a most in my main job when it comes to something complicated and mechanical I always want a backup... If this was true off grid I would just have 2 cheaper inverters But There are 2 things 1 it's a brand new productAnd if it breaks and replacement is 5 to 10 days away... But I also don't want to spend $2000 coming up with a disconnect system... Then it begins defeating the purpose
You also need the inverter password to change several of the settings (not all, but some major ones). And, of course, none of this is documented in the manual, but I already had experiences with GSL, so I knew to ask before I attempted to do my install after China hours and on the Chinese weekend when there would be no support. PM me if you need this info.Some inverters don't support battery-less operation with inverters in parallel. I hope that is not the case with this inverter, but you may find that you are required to have a battery to parallel the inverters. Also I think you must have the wifi dongle in order to configure the inverters in parallel. Make sure you are getting the dongles and everything you need to parallel them. The manual also says that you will need a customer ID for the monitoring software, and that they must create one for you.
Settings for paralleling function in monitor system 1. Set up monitoring for the system, add all dongles into one station. Users can login to visit the monitor system, Configuration->Station->Plant Management->Add dongle to add dongles.
Users can use WiFi/ WLAN /4G /2G dongle to monitor their inverter, and view the monitoring data on computer or smart phone remotely. To view data on smartphone, please download the LuxPowerView APP from Google Play or Apple APP store, then login with their user account.
The "customer code" is a code we assigned to your distributor or installer. You can contact your supplier for their code.
Make sure they test the battery communication before they ship it to you, if it isn't too late. they will send you a video of them doing so. They put my inverter under a simulated load and tested it before it shipped.......and send me a video of them doing so. This way you know you won't receive anything DOA. GSL is very good to work with, but you do have to tell them exactly what you want. They don't do it voluntarily. They will also update your firmware remotely if you ask them. But, you must have a VERY stable internet connection to do so. My Starlink connection wasn't stable enough, so I ended up having to do the firmware upgrade on my 8kw GSL inverter myself.Nick told that they have about 100 inverters in stock ready to ship. I had asked Nick, if I would be getting two inverters from the new production run with the GSL logo, color, latest firmware, etc. The answer was no and he sent me some photos of the inverter in stock, which are white and black with the GSL logo, which is the brand name. He asked me if that was okay. I told him okay, that it was only a personal preference for the GSL inverter to match the GSL batteries. I will be getting the same inverter that the other DIY members have received.
