Brewmaster54
- Dec 21, 2022
- 4
Hello, I am building a skooly for my final years on this earth. I been a maint. mechanic most of my life so I am a pretty much hands on everything, master of none. Electrical is one of my stronger suits but this solar stuff is kicking my butt. All of the reseach I've done and I have a few important questions I need answers on any help will be most appreciated. Even just a point to the answer would be most appreciated.
I purchased the following items..
A growatt 3000 all in one model spf 3000TL LVM 24Volt
Solar Inverter WiFi Module for Growatt Latest Upgrade SPF LVM 120V/240V Remote Monitoring Solar Inverter Build-in Storage
Soc 24 volt 100 amp hour battery with option for a second one if needed
2 of rich solar mega 200 max 200 watt solar panels 24v
1 - 24 volt - 12 volt converter
and all the various cables and fittings and fuse/breakers needed to run the bus.. I feel like I'm missing something to monitor the battery as It has the built in BOM and I have no control over this batteries condition. now it is all installed except the solar panels as I want to seal and paint the roof before mounting them. The system was configured like Will had suggested in one of his videos and everything appeared to be working wonderful. The mains were charging that big ole battery, the 110 volt system was working fine, I really thought this was it, Then I popped the extension cord main breaker while I was hunting and the bus system had to go on battery power. I have the frig running, and diesel heater running and a 1500 watt 110 volt quartz heater running. As you might guess, the battery went dead and the system shut down. The 24 volt battery is now too cold and too dead to even start the growatt 3000 on mains, It just will not start, If left setting for a bit, it will start up for about 10 - 15 seconds and then shut down dead. I'm thinking it is either too dead a battery, or a frozen battery, or both. Either way, This has raised questions I need answers to continue to make a reliable home.
1: with the present setup, is it big enough to live in once the2 / 200 watt solar panels are installed ?
2: just how much power will this SOK 24V battery give me in daily use? and would it be advisable to get another one or two?
3: Is 400 watts of solar typically enough for this small system or should I double it? It is only myself and a dog?
4: I feel like I am missing some sort of monitor I should be having to monitor the system, any suggestions?
5: Can or should you mix batteries, if you can, What would be compatible with my large 24v 100 amp hour SOK battery ?
oh, also the remote monitoring of the growatt is useless, The direct connect to laptop doesn't work and the remote to the android doesn't work, Growatt is of no help as they keep asking for a agency id and no one can tell me where or what it is.. I'm at an impass with them. so I'm going to find someone who has one working and try to pick their brain as to what I might be doing wrong.
I would like to get opinions and or ideas to finish this as I have a lot to do yet and not a lot of space, This is a micro bus 5 window so space is essential and I only want to do this one once. I appreciate any all advice.
