So I have a building with 4 small 2/1 units. It is in SDGE territory in CA and has a huge flat sunny roof (all single story).
Currently the building has 5 meters and 30 amps each unit. We are looking to upgrade the service.
The plan is, replace existing 5 meters (4 units + house) with a single meter 400A main service. Feed this through 2 sol-ark's in parallel and out to 4x 100a sub panels one in each unit. I am thinking these would be Leviton smart panels with whole home energy monitor with ct's to track usage.
Plus a small emergency load panel for the house meter (lighting, security cameras ect).
The part I'm having trouble figuring out exactly is the path, we would have the 400A meter base with 2x 200A breakers feeding into the 2 15k's, then should those two 15k's feed a single 400A panel with breakers for the 100A subpanels?
We would install ~15KW solar and start with 30kWh of batteries - but would have plenty of room to add more solar/batteries later to support potentially more EV charging in the future.
The way I see it we could increase the rent ~$100 a month and simply include electric in rent. We would have a clause about reasonable usage and EV charging would be tracked via CT and billed at a flat rate per kwh. This would also let us attract new tenants easier, allow us to reduce the number of meter account charges billed by SDGE from 5 to 1, and would also be eligible for a tax credit.
Planning to install hybrid mini splits for each unit as well, so those likely wouldn't eat into things too bad even if ran often.
Thoughts?
Thoughts?
