Going to buy 3 panels at 300 watts each. Will be buying 2 Chin 300 watt Lipo batteries in parallel. Would like to run them all in parallel if possible do to some shading during the day. I will be using a 3000 watt pure sine wave inverter with this srtup. I am considering a Victron MPPT controller 150/70 amp.solar panel wiring would run about 40 ft from panels to controller.
My questions are as follows.
1. Do I actually need to run these panels in series in this setup or will a complete parallel setup work.
2.Is this Victron controller a good choice for this setup? I currently run one system on a Renogy and another small system on an Epever controller and do not like either of those controllers.
3. What size in line fuses from each panel will I need to be safe we ith this setup and wire size going from these panels to my controller.
Kind of new to this and this will be the biggest of 3 systems I will be using Thanks for any comments from the community on this. I appreciate lt.
Dennis
Dennis
