I'm not a fan of that Progressive Dynamics converter AT ALL. First, I believe it is being discontinued by the manufacturer and second, it provides a constant current and does not shut off. This will most definitely overcharge your battery in time. You can theoretically disconnect it prior to being fully charged but that means you will have to babysit it all the time.
I suggest something like this:
Buy WFCO WF-9855-LIS Deck Mount Converter/Charger with Lithium-Ion Switch - 55A: Battery Chargers - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
www.amazon.com
It will charge at 14.6V for between one hour and 4 hours depending on your batteries current and voltage, then it switches to a float of 13.6V which is fine for LiFePO4 batteries. You won't have to babysit with this charger and it won't stay in a constant bulk mode like the Progressive one will. It will charge a FLA at 55 Amps and a LiFePO4 at 50 Amps.
