New Victron Multiplus-II 12/3000/120-50 designed specifically for RVs with 30A/50A input flexibility available MARCH 2021
Jennifer
Electricity kills, think twice before acting.
Ours fifth wheel has been in a repair shop waiting on parts since June 25th. Right now I’d be thrilled to have it by the end of September especially since it is our home.
I'm in a Keystone Fuzion as well... do you mind me asking what part you're waiting for this long?
InMyImage
I'm living in my fifth wheel as well so I can understand the frustration. I hope you can get it back on the road soon! Good that you have a place to stay but will be so nice to have your home back! Especially with solar :)
Thanks,silver lining is that I might learn some tips and tricks from you when you start your install. Planning to do a build thread?
InMyImage
Variety. A tree decided it wanted our mid-bunk and pulled it halfway out of the wall.If the shop doesn’t get them soon I’m going to get a list of everything they are waiting on and start cold calling dealerships until I find everything myself. Plus my daughter’s place is only about 90 minutes South of Jayco so I might just go sit in their corporate office until they sell me the parts directly.
Jennifer
Whew... yea that close to Jayco that would be a good idea...that's unacceptable to make you wait that long.
Firstascent
I most definitely am, I'll have some fun custom parts to it as well :) I now have pretty much all the main components, need to order a little wire, build a battery compression case, decide how I want to mount the solar panels (exact position has been decided, but I want tilt function), then I think I'll be ready to begin.
and wow, I typically like trees but that was not nice of him at all haha. I like the idea of stalk...sitting in the office until you get what you need.
DIDDLYV
keep us posted, I am in approximately the same place you are. Have gathered most of what I need the 4 hightec 210 watt panels have shipped. Have the strut channel SCCs Battery Cells BMS most of rest is on its way from amazon. Still need to figure out where to put Multiplus II and the batteries everything else follows from there. I too must build what ever to compress battery cells and mount them in the Elkridge E-292
InMyImage
I got tool boxes and used the shipping foam for my Lishen 272ah cells to pack them firmly in place.
Firstascent
I will! and Yes I as well need to determine final location. I'm almost certain I'm going to put it in the front bay near the generator and rip the existing lead acid/agm or whatever batteries out of there. All of mine going in a Momentum 381M.
good thinking, and free padding too! haha
HRTKD
Boondocker
Somewhere South of Denver
I need help with how to install the ground in a 50 amp RV for the MultiPlus-II 12/3000 2x 120V. The Victron manual says this:
• In a mobile installation (for example, with a shore current plug), interrupting the shore connection will simultaneously disconnect the grounding connection. In that case, the casing must be connected to the chassis (of the vehicle) or to the hull or grounding plate (of the boat).
I'm helping someone do this install and I'm concerned that he isn't doing it right. His only ground at this time is the one coming from the ATS. My take is that the ATS ground is only active (effective?) when on shore power. I don't see anywhere in the Victron manual where there is a separate ground screw (on the case) like I have on my Victron MPPT devices.
How have you handled the ground?
KenB
USA
If you are looking for the ground on MultiPlus-II 12|3000|120-50 2x120V, there is one near all the connections. On the figure in Appendix A, on page 26 of the MultiPlus-II 12|3000|120-50 2x120V manual an arrow points to item "E" and below in the description it states "Primary ground connection (PE) - M8 bolt.
TAS CPA
See KenB's image. "E" to the chassis/ground.
HRTKD
Boondocker
One more question. Using the PC based configuration tool we need to set the phase and then the L2 option. I think the phase is set right, but the L2 options have me stumped. It was tested in "Single phase" mode and it worked well when using a generator. He has yet to connect to actual shore power and I have pointed out that the test of the install isn't complete until that happens.
cinergi
1.21 Jigawatts
Generally in North America you'd want Dual phase 180, not 120 (that's the degrees out of phase, not the voltage).
As for the L2 options, I'm not familiar with those but it probably relates to how to handle when shore power is NOT 180 degrees out of phase. Are you unable to use Victron Connect to configure this unit? Much better interface (it replaces VE.Bus System Configurator).
HRTKD
Boondocker
I would not have suspected 180 to be the setting to use. Huh. He doesn't have the Bluetooth adapter yet, only the USB adapter is available at this time. I thought the USB and PC application had more options to configure than the app through Bluetooth. He does have the Bluetooth adapter on order.
cinergi
1.21 Jigawatts
Yup 180 degrees out of phase.
Victron Connect works through the MK3 as well. Either PC or Android. They've been expanding Victron Connect capabilities and it can handle split-phase inverter configurations now.
sparklehunt
I'm a bit confused to the purpose of the unit.
from the SPS site, are 50a RV electricals normally wired with a Main and Sub panel? So the 'main' loads are not available when off-grid?
Also confused to when you need 50a,120/240.When do you actually exceed a 120v/30a service, that's ~3600W! Seems like a lot.
do 50a RVs have 240V appliances that are intended to be used with a 50a, 120/240 split phase external connection?
Firstascent
Pretty easy to go over 30A, simply run two A\C units. My fifth wheel has 3 A/C units :)
Also, it’s still always 120V. For simplistic terms, think of it as two hot (120v) legs. That’s where the 240 comes from but it’s still just 120v.
(There’s actually 4 wires instead of 3 like you would see on a standard cable you plug into your wall outlet at home)
sparklehunt
three A/C units! Ok now makes sense. Would probably not need this for a van build then.
I understand the part about the 4 wires, the receptacle has L1, L2, N, and PE/gnd. Theoretically, you could run US 240v appliance off this if your rv had it. I was wondering if any RVs actually had them.
Next question: why don't RVers just install more solar and a bigger inverter then? Solar panels are cheap nowadays and you have the roof space. Difference between 3kw and 5kw is only ~$300 (edit: more like $700, still) and a ~13kWh batt is like ~$2000 with reputable Eve cells. I think @cinergi has such a system. Then you don't need to be tied to a plug and it should pay itself within a year or two?
HRTKD
Boondocker
The roof of an RV is like an obstacle course. Vents, skylights, antennas, A/C unit, they're all over the place and in random positions. Trying to fit solar panels is like playing Tetris on level 10.
