Steve Fractals
- Sep 6, 2022
- 172
Hi guys,
So like lots of other people, I'm thinking of trying some DIY Solar. My south facing roof is really to small to fit anything other than maybe 2 panels so I thought I'd try with a shed based 2 panel system given that my shed has the same south area as my main roof. I only want to power a tv or radio and a lamp from this initial system but want it grid backed up and auto switched.
I want a system that is mains/grid backed up but I don't want to feed back to the grid as wouldn't have enough spare power anyway and don't want all the hassle of approved systems etc. so whatever system I end up with must have the option to not feed into grid but of course would be nice to have that as a selectable option if possible. I also want a system that I can grow without having to keep swapping out invertors etc. if that's doable.
From my reading it seems I either need a hybrid or a myrid of other separate boxes e.g. invertor and charge controllers etc. am I correct on that?
So my current thinking is some sort of hybrid system but like I said at the moment I plan to start with only 2 X 400watt panels and and some probably lead acid batteries (banks of 2x12v in series to make 24V) (but the option to switch to Lipo etc later on would be good). Again it seems I should be looking at a 24V system (need 230/240 AC output) but I could be completely wrong as a newbie lol.
So what if any hybrid invertor/chargers systems would people recommend that could grow from 2x400 watt panels to say a 3KW system later on (might end up addicted and build a ground based panel system, or would you say stay away from hybrid and go some other route that can still offer grid backup/tie-in?
I absolutely realise that I've still have lots of research to do but any starter guidance even if that's just a link to similar newbie questions would be useful as its a lot to get my head round and would be useful to at least have a good starting point.
