So is this series or parallel wiring? I then need to connect from this to my MPPT controller.
The image, if connected, shows parallel. For series, put the Y cables away. Connect one panel's red to the other panel's black. The red from one panel and the black from the other panel (that are not connected) are your series output. If you are old enough to remember D cell flashlights, the batteries stacked end to end, negative bottom, sitting on positive top of the other battery. Any series power source connects the same way. Voltages add up, so if your panels are 18v open circuit, you should measure about 36v in the sun open circuit, if you have them connected in series.
