Replied in PM20kw wasn't going anywhere, it was a software glitch.
Thats crazy, thank goodness they didn't set your HZ to 50. This is the reason I disconnected mine from the WiFi. Thanks for letting us know about this.Well, I think I figured it out.
Someone logged into my account yesterday and reset all factory options. PW changed. MF.
Do you use the password for this service anywhere else? Is it a good password or one that would be considered weak?Well, I think I figured it out.
I'm confused, how can someone other than the user name log into the inverter? Wouldn't that have to be a hack into the service end to act as someone with rights?this is the user that reset to default
The username there matches the username here. Guessing the account was compromised (most likely scenario).I'm confused, how can someone other than the user name log into the inverter? Wouldn't that have to be a hack into the service end to act as someone with rights?
Sorry, didn't catch that the name matched. Guess the way you said this is the user, my brain assumed it was different.The username there matches the username here. Guessing the account was compromised (most likely scenario).
Yeah, I just checked my cameras. I was driving back from lunch when it happened. Maybe a pocket dial thing? Anything is possible. But me, going in and setting all settings to default is not something I would have done purposely.@millsan1 A while back, I thought my account had been hacked too, but it turns out I was trying to record a video.. I played it back, and realized I had done it myself. I suspect the likelyhood of someone hacking your account to mess with you, is pretty low. Occams razor would sugest that.. like my scenario, you likely did it without realizing it.
my best bet its either the account is compromised or the user reset to default accidently, because looking at the logs there's to many setting changed by a single user name which is the owner account. any settings that changed is being recorded except if the setting is done on the inverter screen.Sorry, didn't catch that the name matched. Guess the way you said this is the user, my brain assumed it was different.
Yeah, that is me fixing the problem.my best bet its either the account is compromised or the user reset to default accidently, because looking at the logs there's to many setting changed by a single user name which is the owner account. any settings that changed is being recorded except if the setting is done on the inverter screen.
Are you sure you should be posting details from people's logs like this? I would not be happy if you did that to me that's for sure.my best bet its either the account is compromised or the user reset to default accidently, because looking at the logs there's to many setting changed by a single user name which is the owner account. any settings that changed is being recorded except if the setting is done on the inverter screen.
I'm not sure why would be bad it just a history logs of setting, there's no sensitive information in my opinion.Are you sure you should be posting details from people's logs like this? I would not be happy if you did that to me that's for sure.
besides my serial number and station name?I'm not sure why would be bad it just a history logs of setting, there's no sensitive information in my opinion.
you posted your serial number here. and its useless to anyone unless you have a super admin account with luxpower or EG4.
