20 watts (24vdc x 0.9A) of no-load run power sounds more realistic for 1000w to 1500w sinewave inverter.
The output PWM L-C filter has some reactive currents at no output load that causes greater no-load idle losses.
Dominate no-load power consumption is driving the MOSFET gates at 20-30 KHz chopping and reactive current of L-C output filter.
Since the number of parallel MOSFET's and size of MOSFET gate capacitance goes up as inverter power capability goes up, the higher the inverter wattage rating the more no-load battery current. Some inverters shut off some of the parallel MOSFET's at low power but this has negative side effects for surge loads.
