HalfBaked
Ever the student
Second post, reading constantly, but still very noob.
My current plan is to upgrade from 12 to 48v offgrid. I've been trying to cram knowledge as quickly as possible as my current system requires a few hours of generator every evening to make it through the night. The AGMs are dying.
After strongly considering the cheapest (AIO) routes, then reading more here, I am now leaning towards a more reliable, modular tier 1ish approach.
I currently use the Magnum 2812 inverter/charger and Morningstar ts-mppt-60 with 3kw of scattered arrays. Both units have performed flawlessly for 4 years, which also helped nudge me towards reliability.
The plan -
Continue to use the ts-mppt-60 as it seems 48v lithium compatible through the custom user settings.
Buy from current connected:
Victron 48V MultiPlus-II UL1741 3kVA 120V Inverter 35A Charger
SOK 48V 100Ah (x4)
My needs are small (to me), roughly 8kwhr/day for everything except a 14btu (1200w) AC window unit, that I currently run on generator as needed. It would be super nice to be able to run that from solar for 8ish hrs a day. The next upgrade (maybe next year, as funds permit) will be a mini-split, ideally the type with it's own dedicated panels.
I see scary discussions about victron add-ons and how they get costly. Eg Cerbo gx, Lynx, etc. I just need a simple, reliable system. I have no need for external monitoring or any other special needs.
Questions:
Will I need these extras?
Will my old SCC play well with the Victron inverter and SOC batteries?
Will my current dirty-power generator play well with the victron or will I need some sort of "chargeverter"?
Am I missing any components?
Better plan, knowledge gaps, anything else I should be thinking about?
Thanks everyone for your time and expertise as I learn the ropes.
The plan -
SOK 48V 100Ah (x4)
Questions:
