Hey Folks,
I am building out a small DC system with a 1000W inverter for a new trailer I am getting in a few weeks... I am building it all on a bench so it can be setup and ready to go. I won't get into the details of the whole system but I have a bit of a brain fart issue and I cannot get the numbers to line up. Maybe something stupid on my part, or maybe one of the meters are not accurate.. I have mathed hard and cannot see the answer though..
I broke the system down as small as I could when I found the "issue"
Right now its a single 100AH Renogy Lithium battery
Connected directly to a 1000W Motomaster Inverter.
I have a Kilowatt plugged into the Inverter.
I have a small 120V fridge plugged into the Kilowatt.
Fridge ----- Kilowatt ----- Inverter ---- 100AH 12V Battery
Nothing else connected.
With the compressor running Renogy is showing -5.1A at 13.2V on the LCD Display and the Bluetooth Dongle
The Kilowatt (with the fridge plugged into it) is showing .91A at 132V.
If the Fridge is drawing .91A at 132V =120.12W
120.12W/13.2V = 9.1A DC (Not accounting for loss in the inverter)
9.1A does not equal the 5.1A Renogy is showing me....
To try and confirm things I used my cheap AC clamp meter on the AC line and measured 0.75A AC or .75A x 132V = 99W
I don't have a DC Clamp to test the DC Side..
Going the Other way, 5.1A x 13.2V = 67W
I have almost 30 - 55W coming from the ether that I cannot account for and not considering loss in the inverter.
What am I missing...
Hmmm...
Edit
For those observant in the group you may notice the Renogy meter is showing 3 batteries connected. The photo is when I had 3 batteries in parallel. The numbers are more less the same when I drop to a single battery other then the hours remaining are 1/3.
Hmmm...
Edit
