TheCoachStone New Member Joined Feb 12, 2021 Messages 127 Location Birmingham, AL Nov 2, 2022 #1 I keep finding different information about what do to about the 3000TL bonding. I have attached my sample drawing. Since they are bonded in the unit, do I just not use the green screw? Or, do I need to attach the green to something else?
T timselectric If I can do it, you can do it. Joined Feb 5, 2022 Messages 18,766 Nov 2, 2022 #2 Do not use the green bonding screw. And add a separate ground bar.
TheCoachStone New Member Joined Feb 12, 2021 Messages 127 Location Birmingham, AL Nov 2, 2022 #3 timselectric said: Do not use the green bonding screw. And add a separate ground bar. Click to expand... Ok, that is what I was thinking. What do I attach the other bar to in the box?
T timselectric If I can do it, you can do it. Joined Feb 5, 2022 Messages 18,766 Nov 2, 2022 #4 It mounts to the box. And the green wire goes on it. The existing bar is the neutral bar. (White wire)
TheCoachStone New Member Joined Feb 12, 2021 Messages 127 Location Birmingham, AL Nov 2, 2022 #5 timselectric said: It mounts to the box. And the green wire goes on it. The existing bar is the neutral bar. (White wire) Click to expand... So, just something like this - https://www.homedepot.com/p/Square-...Panel-Load-Center-PK7GTACP-PK7GTACP/202353316 And I just figure out where to attach it as long as it does not touch the neutral bar?
T timselectric If I can do it, you can do it. Joined Feb 5, 2022 Messages 18,766 Nov 2, 2022 #6 TheCoachStone said: So, just something like this - https://www.homedepot.com/p/Square-...Panel-Load-Center-PK7GTACP-PK7GTACP/202353316 And I just figure out where to attach it as long as it does not touch the neutral bar? Click to expand... Yes And it attaches to the two holes at the bottom left or right.
T timselectric If I can do it, you can do it. Joined Feb 5, 2022 Messages 18,766 Nov 2, 2022 #7 Actually any corner of that panel.
TheCoachStone New Member Joined Feb 12, 2021 Messages 127 Location Birmingham, AL Nov 2, 2022 #8 timselectric said: Actually any corner of that panel. Click to expand... Much thanks! Now, I just have to remember what style box I bought. Also, is my black wire correct to be able to use both sides at 120v?
TheCoachStone New Member Joined Feb 12, 2021 Messages 127 Location Birmingham, AL Nov 2, 2022 #10 timselectric said: Yes Click to expand... Thank you for your help!
