Freaking vi is the reason I became a Windows admin vs a Unix admin. ?
Whoever thought up the key combinations was high at the time.
Vim is my default editor. It's perfectly sane. If you want crazy key combinations, go Emacs.
but when i check status it is not running. I can only assume my path is incorrect?
bash: ./node_exporter: No such file or directory
Personally, I find nano better. Whatever key combinations you might like/dislike, they're shown at the bottom of the screen - and you only really need Ctrl-x :·)Vim is my default editor.
checking i get error at end
level=info ts=2021-12-11T18:48:01.305Z caller=tls_config.go:170 msg="TLS is disabled and it cannot be enabled on the fly." http2=false
it works fine manually ran but will not load automatically.That's not an error - should work fine. Try checking on port 9100 with a browser.
i do and i assume its incorrect
[Unit]
Description=Node Exporter
[Service]
# Provide a text file location for https://github.com/fahlke/raspberrypi_exporter data with the
# --collector.textfile.directory parameter.
ExecStart=/usr/local/bin/node_exporter --collector.textfile.directory /var/lib/node_exporter/textfile_collector
[Install]
WantedBy=multi-user.target
Vi is tough to learn but it's so much faster than any other editor once you know how to use it. I only use ssh and vt100 terminals as i work remotely.Lmao I use nano editor I guess I’m not admin material
I just ordered a JBD BMS, i will add support for it soon!It's on my to-do list... Sadly, I have a very long to-do list...
It ties in with this:
JBD / Overkill BMS Monitoring
any update on a setup/install guide? Been trying to figure this out all day.diysolarforum.com
Funny. I used to repair those VT100 terminals when I worked for Digital Equipment Corp.Vi is tough to learn but it's so much faster than any other editor once you know how to use it. I only use ssh and vt100 terminals as i work remotely.
I had to take a break my wife was giving me the look after 5 nights trying to get this to work. I’m closer now but still a ways to go… just node exporter and then I need to figure out where to put scriptsYour node_exporter isn't installed in /usr/local right? It's wherever this './node_exporter' is located : /prometheus/node_exporter-1.0.1.linux-armv7 probably.
You also need to modify the arguments to "--no-collector.mdadm --collector.textfile.directory=/ramdisk"
