Problem - heat. Solution - freezer.
Actually it's a new hybrid chest freezer which doubles as a fridge - and highly efficient at that, due to the high value insulation. I've added a separate thermostat to keep it at approx 22c rather than 4 (too cold) or the often 40+ C in the shed where this is situated (Australia).
The setup inside is a 16kw CATL 304amp 16S with a JK BMS and the new Growatt 6kw SPF 6000 that seems to work as it should. Fingers crossed. With 4kw of second hand panels. My main concern is that if the Growatt packs it in there's a possible 370 vdc headed unregulated into the lifepo4 (after frying the JK BMS first). A possible 85 kg bomb...
And those panels were picked up for $20 each ?
