I have 7kw solar, 2x MS5048, 500 amp smart Daly, 2 amp balancer, 2P16S 280Ah LiFePO4.
I am trying to keep my batteries between 20-90% SOC for longevity but I want to get to 80-90% as quickly as possible.
Setting up the charging voltage at 56.8v and letting the BMS stop charging at say 53.8v or less caused my inverters to go overvolt on the DC side because of the spike which is generated when the BMS abruptly cuts the charging.
Am I wrong doing it this way, is there a better way?
I have ordered some ultracapacitors to wire them in parallel with the BMS to soak up the charge more gently when the BMS cuts the charging. I will also place a 60v TVS diode across the charger. What do people think?
Circuit simulation
Circuit simulation
