Just completed the installation of my system. Did not blow up, did not start a fire!! Everything works, thanks to Will for putting out the great videos and making me feel comfortable spending the $ to install it.
Straightforward system. 24 V Growatt SPF 3000TL LVM, EG4 24V Battery (connected via the ethernet BMS Lithium setting) and a 450 Watt panel on the roof of the RV and a PV disconnect switch between that and the inverter. 10/3 ext cord out of the inverter to a 15 to 30 amp dog bone to the shore power input on the RV.
Ok here is what I am doing on startup. Plug in RV, turn on battery, turn on inverter, wait for inverter to start, turn on PV.
On disconnect. Turn off PV, turn off inverter, turn off battery, unplug RV.
Is this the way I should be doing it?
