I use the voltage trigger relay on the heltec 5a balancer. Recently I am wondering if I can use the dry trigger relay of the new JKBMS Inverter instead........less ring terminal, resistance at the battery terminals?Thanks for the info. I watched several of Andy’s videos from Off Grid Garage as well. Seems to work well if you can control them to work only when needed or at certain voltage levels etc.
Note: I am using Heltec 5A balancer, JKBMS 2A and Neey 10A balancer in one go.........although the Neey 10A kicked the bucket recently, currently waiting for new one from Enerkey (should be same model, just different branding)
edit: Hmm......JKBMS has dry trigger "Cell over voltage" or "Battery over voltage", but the value can't be set to 3.45v.......Or do I misinterpreted the "Cell over voltage"?
