Flip
Hey y'all. So I'm attempting to wire a second inverter to my system (24v, 300ah, Lifepo4 Fortune cells, Overkill 24V 100A BMS). When I hook both inverters to the bus bars and flip the breaker back on the BMS discharge protection trips and reads short circuit. If I hook the inverters up individually and flip the breaker, it's fine. If I hook one inverter up with the breaker off and hook the other inverter up after I flip the breaker back on, it's fine, however, if I flip the breaker off and on again it trips short circuit again. I have to believe it's a setting in the BMS that's causing this, but I don't know which one or why.
Does anyone have any experience with this issue? Is there something I'm doing wrong? Thanks in advance!
