Maple
Hi DIY Solar Folks,
Thanks to your many helpful posts, I am considering adding solar power to my rural home near Madison, WI.
Could you please help me understand panels and SCCs (for an off-grid system for use during a power outage and to reduce electricity bills)?
Suppose I bought this panel:
NE Solar 370W Mono Solar Panel NESW 370MH-M6:
VOC: 41 V
ISC: 11.42 A
Temperature coefficient of VOC -0.29% / degree C
IMP 10.82 A
VMP 34.2 V
The record low in my area is -37 degrees F = -38 degrees C, so I think the VOC increase from 25 degrees C is
(41 V) * (25 - (-38) degrees C) * (0.29% / degree C) = 7.5 V
and the VOC at -38 degrees C is 41 + 7.5 = 48.5 V.
I have a SW-facing standing seam metal gambrel roof on which I could mount panels with S-5-N clamps. (I installed the roof, leaving ridge anchors, and can safely install panels. I'm not excited about leaves, rodents, snow (which slides off the metal and therefore also off panels in reasonable time), and maintenance, but a roof install would save money, install work, and aesthetic cost compared to ground mounts.)
On the top 14-degree roof, I could install 15 panels with these Victron SCCs:
- $184 MPPT 150/35 3s2p 6 panels, VOC=48.5 * 3 = 145.5, ISC=22.84
- $184 MPPT 150/35 3s2p 6 panels, as above
- $184 MPPT 150/35 3s1p 3 panels, VOC=48.5 * 3 = 145.5, ISC=11.42
On the side 70-degree roof, I could install 10 panels:
- $479 MPPT 250/70 5s2p 10 panels, VOC=48.5 * 5 = 242.5, ISC=22.84
On the garage 14-degree roof, which is shaded by the house 2nd floor after late afternoon, I could install 9 panels:
- $184 MPPT 150/35 3s1p 3 panels, as above
Have I done these calculations correctly?
Is there a better arrangement of strings and SCCs than what I've proposed?
Thank you.
VOC: 41 V
ISC: 11.42 A
IMP 10.82 A
VMP 34.2 V
Thank you.
