merrillbalan
- Feb 17, 2022
- 29
I plan on using 6000Watts combine power instead of 240V Split Phase from my 3000Watt Growatt LVM24p. Per manual, I need to connect both Hot from Inverter 1 and 2 and both Nuetral from Inverter 1 and 2 as well as connecting both Ground from inverter 1 and 2.My question is, since I have an unused 30amp NEMA 10-30P. I would like to utilize it. Can I use the splitter below to plug in my 2x growatt 3000? This is only because I ran out of space in my main breaker and do not want to run new wires, but I have to make sure that I can never use more than ~25amps combined from both inverters of course.
