I need advice from the experts. Is parallel balancing a bad idea? I have 8 LG 9.8kw ESS batteries (14s). The plan is parallel them and connect to a 5K charger/inverter (Outback Skybox). Rather than using 8 separate 80A Daly BMS, I'm thinking of using one 400A BMS with a 2A active balancer using the rig i put together. That way, the active balancer can do the bulk of the balancing and not just top balance and the BMS can protect the batteries.
Please give me suggestions. Thanks
