Ohms_Cousin
- Nov 6, 2020
- 59
Have read read many posts here re paralleling cells. Not seen anything really in depth about it though.
I get that a group of cells that are paralleled all have the same voltage and that you lose visibility on each individual cell.
What I am trying to figure out is what is the practical limit to stop paralleling cells from a safety standpoint? A 2P paralleled cell set seems to be fairly low key in terms of safety. With only 2 cells and an avg voltage there doesn't seem to be too much that could go astray.
But how does it look at 4P or 5P or 6P ? How much more risk does one take on for every extra paralleled set of cells?
My question relates to getting enough capacity in kWh without using too many paralleled batteries in a bank. I came across a cylindrical cell that is 3.2v 22Ah. That is only 70.4 Wh per cell. At 16s that is only 1.126 kWh in that battery, so would take a lot of paralleled batteries to get to my target of around 50kWh.
Seems it would make more sense to go 4P16s = 4.5 kWh in one battery - so still needing 10 or 11 batteries to get up to 50kWh.
If one were to go 6P with the 3.2v 22Ah cells (6P16s) then it is 6.7kWh per battery and cuts number of batteries down to about 7 or 8.
The more cells one puts in parallel the less batteries needed. Depending on BMS chosen this makes a big difference in BMS costs.
Other factors are getting even charging into so many batteries. I read here that to get even charging one should stick to either 2 or 4 batteries in parallel. Seems to be a lot to consider in all this.
Why cylindrical cells? I want to build a battery for a boat. I have read at several sources that bigger prismatic cells can be trouble in a boat and that one should stick to around 100Ah if using prismatic cells. Seems the best way to avoid the whole is to use cylindrical cells - they offer better cooling with more surface area exposed to air and should overall be more robust because of shape.
I have read how in parallel the cells are all the same voltage and that one loses visibility on individual cells and understand that. However how big an issue is this at 4P or 6P? Is there a point that it becomes too big a risk and its better to go no more then, say, 4P and just put more BMS's into a system? Or is this not a thing at all to be concerned about?
