On page 51 of the current installation manual it shows a bypass transfer switch. If the inverters are wired this way and their is a grid outage, you will need to manually change the bypass switch in order to have power with the grid down. Wouldn't this be better served with an ATS if you do not want to pass through?
My array (structures have #6 copper to grounding rods) is 300+ feet away from the inverters. My electrician told me that i need to run #10 ground wires from the inverters to the arrays. Do I just land them in my dc disconnect boxes grounding rail and call it good (nothing else is connected to it)?
Does anyone have any recommendations for AC combiners other than just using insulated multi-tap connectors?
