We want a pellet stove and I was wondering if there are some pellet gurus out there.
The gravity feeds seem to need a lot of maintenance as in scrape the drop hole daily, add a bag of pellets daily, and gum up with creosote, (probably due to low temps/design)
I've read 100w up to 500w for ignition, but then read somewhere else the fans suck down power beyond that, not sure. I have 18kwh battery and can power a pellet stove, but at say 400w continuous in the winter on snowy or cloudy weeks it would be hard.
A 20" box fan at home depot uses 70w max so is a blower necessary to burn the pellets? I assume the blower keeps the hot temps.
Any particular stoves or insite would be great. I can even swap for an effecient fan.
We have 9'6" ceilings and plan to go straight up for more heat off the pipe.
