frankz66
Hello everyone, I wanted to have your opinion on the performance and voltage drops regarding the copper busbars.
My perplexity is due to the fact that previously in the m I system I had separated and connected all the positives and all the negatives in an equipotential bar to be clear of the screw type perforated in brass, those that are used in electrical systems to connect the masses or voltage cables. I replaced these screw-on brass bars with two 3mm 99% pure copper bars.
To my surprise, I noticed a notable difference in performance. That is, in the morning the lead-acid batteries, I had about 12.36 volts of residue, but turning on the fridge I noticed a cue of 500 watts and a drop in battery voltage of 0.70 volts. With these copper bars that I replaced, the voltage drop was only 0.13 volts. Is it possible that the copper busbar made me achieve this high performance? The performance difference for the drop is 0.60 volts less with copper! Thank you .
