KalebTheMaker
Hi all,
Now that winter solstice has come and gone, I am ready to start my new installation! I have been planning and talking with a few vendors, working out design and quotes and so far so good. I'll post another thread on the full system design, but I wanted to get your opinion on the two options I have for panel placement.
There are two locations for panel placement, the primary site looks pretty great, and the secondary site is not so great. The reason I am not just using the primary site is that it is about 1000' feet from my house and shop. The secondary site is about 200-250' from the house and shop. I have another post about that issue here:
https://diysolarforum.com/threads/1...te-to-house-shop-questions.51389/#post-652274
I am close to the end of the planning stage of this project, and here is a brief description of the system.
I will have about 9500-10000w of panels, and 600Ah of 48v LiFePO4 batteries. Victron RS charge controllers, and two Victron Quattro's for a split-phase system. I will probably have two strings in the panels, with 4 DC conductors running the 1000' or 250' to my "power shed" where the Victron equipment will live. I don't plan to discharge to 100% daily on this system. I am sizing it this way for running my shop, which does not run at full capacity every day. It's sized this way for when I have to run the CNC or welders.
My question to you all, is do you think that the secondary location is "good enough", or should I spend the extra money on ~800' more of conduit, conductor, and pull boxes?
According to https://footprinthero.com/solar-panel-charge-time-calculator I should be able to charge from 100% DOD in 3.8 peak sun hours.
Here are a few pictures I stitched together from a sun path app I found (the app is called "suns path" on IOS). I took these pictures on Dec 20th, 2022.
Note: On the secondary site, all of the close oak trees will be cut down for firewood. The fir trees in the background are further up the ridge, and out of my control.
Any input is appreciated.
Thanks,
-Kaleb
Thanks,
-Kaleb
