Hi everyone, I've read all I could over the last few months and I'm seeking advice on my proposed system diagram before I order and install all my components in the next month. Please give me your thoughts.
The basics:
Version 1 plan:
Future ideas for efficiency:
Please let me know if there's anything wrong with this plan to start, you'd strongly suggest different hardware (like Growatt + SOK instead of EG4), or any other insights you might have. Thanks!
The basics:
- 30 foot class C toy hauler, meaning the living area is quite small (8’ x 16’)
- I will be living, working, and riding dirt bikes out of this vehicle for a few months at a time
- I’ll be using this in some desert climates, so outdoor daytime temperatures may exceed 100F
- I’ll also be using this in some mountain climates, when the temperatures are just above freezing
- I can generally park in full sun with no obstructions
- Main power requirement will be mini split, secondary will be laptop + monitor + Starlink, no slide outs (biggest 12V draw is starting generator)
- More concerned with simplicity of DIY build than money or pure efficiency in version 1. Just gotta get on the road and see what doesn’t work before premature optimization.
Version 1 plan:
- 3300W of solar on elevated roof rack (6 x 540W panels at 49 VOC, in 6S configuration for 297V PV @ 13.72A ISC)
- Add panels, EG4 300W 48V AIO, and one EG4 48V 5120Wh server rack battery
- Leave existing 12V AGM house battery in place to start generator or starter battery in emergencies
- Wire the output of the AIO into the existing breaker panel to provide 120V (and wire the shore power/generator output cable into the input of the AIO)
- Let the existing Parallax 7300 Series 7345 Converter in the breaker panel provide 12V and keep the house battery full
- Consider accepting the inefficiency of both the AIO idle draw and the PV -> 120V -> 12V conversion for the 12V system and house battery
- Just add a second server rack battery and don’t worry about efficiency at all forever
- Add Chinese diesel heater if overnight winter heat requirements can’t be met with solar and two batteries
- Add 48V to 12V battery charger (cannot find one from a reliable manufacturer, the Victrons are only converters, not chargers)
- Go Victron with separate components to reduce AIO idle draw
- Convert fridge to either AC or DC
- Current propane fridge is dying, and if I have to leave the inverter on most of the time for the mini split, why not just run the fridge off AC?
- Convert everything to DC
- Mini split, fridge, Starlink, laptop, monitor, can all be converted to DC
