solarbits
As a newb to all things electrical, the more I learn from these forums, the more cautious I get, for better or for worse.
Question - I have 1 total service panel, and had an electrician put in 2 Reliance Pro/Trans 2 transfer switches connected to 10 circuits in that panel. Is it ok to plug each transfer switch into the same Delta Pro, or will I create a problem with two neutral paths and let the magic smoke out?
More details - It's my understanding that the Pro/Trans do not switch neutral, and that the Delta Pro does not bond neutral. I also read the warnings about not plugging the Delta Pro into an AC outlet while also connected to the transfer switch, so it is connected to and charges only with DC (a 600W power supply).
Thanks!
Thanks!
