dahluwalia
So I'm putting a backup hand cart system. I also have a generator. The gas gen can do 220v but my solar gen can not. I will need a electrician for sure but what does that set up consist s of
so 2 very differnt set ups , sounds very expensive i think I'm over my head again .I do have a power strip on it .Ithink if I could only do one it would be the gas generator as the cart can come inside with a bunch of extension cordsGenerator plug in needs a transfer switch on main incoming before panel. Assuming you have enough generator to run everything.
The portable solar power should probably feed a “critical loads” subpanel also behind a transfer switch to isolate from grid power and generator.
That’s the simplest no details answer.
well not attached to the grid , but I hoped that if the power went out I could plug it into the house and power up a few rooms and a fridge .pull out a few panels and back that up with a generator if no sun stormy situationA hand cart - as in not attached to the grid at all?
Just some kind of wagon with power tools and a BBQ?
A aio on a hand truck,dolley ,yes for back up to run a few thing until the power come on or until I pull out a generator but instead of extending cord i would like to plug into my house as well as a generatorA hand cart - as in not attached to the grid at all?
Probably are over your head, currently, but you can learn new things and are already; then you become not over your head.so 2 very differnt set ups , sounds very expensive i think I'm over my head again
It’s perhaps likely that the generator may want a separate “critical loads” panel, too. Either way you need a transfer switch.Ithink if I could only do one it would be the gas generator as the cart can come inside with a bunch of extension cords
As others have mentioned plugging a generator or power pack into the house requires an ability to isolate grid power. There are several methods that it can be safely done and if you use an electrician I am sure he/she will set it up properly.Thanks I will look at the vids . I have watch more than a few but I think will usally is more about the build then atcully plugging it in to the house ,but I will watch thru more closely thanks
Most vids skip the book into house part I think?There are several videos that the owner of the Forum has made that can show you much of what you want to know. Look up to the top of the Forum for the link to DIY Solar Videos. If you then have a specific question it will be easier for someone to respond to.
One e poo electrician want over 3k for 2 system and two plugs for solar system and then now that is over my head! I want safe simple and cheaperAs others have mentioned plugging a generator or power pack into the house requires an ability to isolate grid power. There are several methods that it can be safely done and if you use an electrician I am sure he/she will set it up properly.
Do not attempt this yourself!
Which ones I'm not seeing muchThere are several videos that the owner of the Forum has made that can show you much of what you want to know. Look up to the top of the Forum for the link to DIY Solar Videos. If you then have a specific question it will be easier for someone to respond to.
