lboucher26
- Sep 24, 2022
- 54
Hi All
So i am getting concerned that my master plan might fall apart.
Long story short, one of my main plans in going solar was to power my pool pump, as it seems like the perfect, constant load, on all day.
Along this journey i learned that Variable Speed pool pumps are way way more efficient, so i upgrade 6 months ago (ish).
Black and Decker 1.5hp in Ground.
Pool pump always ran fine.
Finally got it hooke up to EG4-6000EX about 2 months ago.
Ran great for 1.5 months.
During this time, I had the inverter set to EG4 mode.
Then i had an issue with the 2 Lifepower4 batteries i have getting drained... So now i am a bit skittish to trust EG4 mode, based on other feedback on the forum.
I think this may have been because i had the dip switches on one battery wrong, and the inverter would only talk to 1 battery.
(I did talk to SS, got general support, and some vague answer, but not specifics. Does seem like a shortfall of the software.... Even in EG4 mode is should see the voltage cratering and do something....)
I currently am using Solar Assistant to connect to the batteries, and then Solar Assistant switches the inverter from SBU to SUB.
What i have found, is that when Solar Assistant changes the mode, the Pool Pump faults with a E-00.
This error is not in the manual.
Black and Decker Service was responsive, and told me about what i expected.
E-00 is a general fault where the pool pump doesn't know what happened...
Of course, they suggest i connect the Pool Pump direct to Grid all the time....
I think my next step is to remove Solar Assistant from the equation and try either EG4 Mode again or USE mode, and see how the Pool Pump behaves.
Anybody have similar experience?
Anybody else powering a Variable Speed Pool Pump off an EG4 inverter? If so, what brand of pump?
Any suggestions for a device to put between Inverter and Pool Pump that would "Smooth" or otherwise shield the pool pump from voltage transients when switching from SBU to SUB?
Thanks
Thanks
