solarpooldiy
Hi folks. I recently repaired my 18x36 in-ground pool, and to extend the season, installed an electric heat pump pool heater. I had already had power at the pool (240v, 20 amp service), and hadn't considered the cost of running additional power for the heat pump when I ordered it a few months ago. The pump needs 40 amps at 240v, so for wiring, it needs a 50 amp breaker in my panel at home, and a new run of 60 amp wire to the pool. I don't have 50 amps of breakers available in my panel, so I need a new subpanel at home. I also need a run of 100 feet with 60 amp wire, put in a Schedule 40 PVC pipe, 2 feet down, in a trench run from my house to the pool. I'd probably also (for safety), need an outdoor subpanel (or at least a breaker) at the pool so I can shut off the power quickly in case of an emergency.
So, for those keeping score at home, I need:
1 home subpanel
1 100 foot run of 60 amp wire, in a PVC pipe, in a 2 foot deep trench
1 weatherproof outdoor subpanel
In talking about getting this work done with a couple experienced electricians in the area, it's looking like it'll cost between 5k and 10k to do this work. This is a one time cost, and then I have to pay for the electricity....
That got me thinking - am I better off buying some solar panels, and either ground or pole-mounting them, and wiring them to a 240v battery solution to run the heat pump? Or maybe I don't need a battery, and just need a controller that can output 240v? I was thinking the battery could regulate the incoming solar power to put out a steady supply to the heat pump, whenever it can...
I won't need much in the way of electrical storage capacity, just a place to land the power from the solar array. I can install the battery right next to the heat pump and save myself the long run of 60 amp wire. I figure if I can spend 10k on solar, I can at least recoup some of those costs by running the heat pump (and maybe the pool pump) off solar...
I don't need to run the heat pump 24x7 - if it runs as long as we have sun, that's fine. The goal is to heat the pool a bit more so we can start the pool season earlier (May?) and end the season later (October?).
Is this too crazy an idea to consider? Or might it work?
1 home subpanel
