Haykin
I just finished installing a small solar resource in my shed to help reduce power consumption for my storage freezer.
I’d like to get feedback on how I should configure the system to handle the load properly with the parts I have installed or what I could do to improve it with as little $$ as possible.
I followed Will Prowse video on setting up a 12v system and I have an MPP solar 12v 1kW all-in-one unit managing power, a single 12v LifePO4 100Ah battery and two 100W monocrystalline solar panels in parallel.
Everything appears to be running well and I even plugged the freezer into it and after an initial auto-switch to utility to provide enough juice for the freezer to start up it switched back to battery and ran for the rest of the day on battery with solar providing recharge current.
I should note that I referenced Will Prowse MPPsolar configuration settings tips to set mine up. Although some settings were not available to me. Assuming this was because I’m in a 12v single battery configuration.
One thing I did not take into consideration was after sundown. At some point around 10pm the unit started to alarm [even though the audio was disabled] and there was no fault code on screen, it was just beeping over and over again. Even after I turned off the power switch. It wasn’t until I unplugged it from utility that it shut down and screen went black.
Is it safe to say that the alarm was due to battery being discharged and no source of recharge power?
This morning I changed option 16 in the config to include utility and solar as the simultaneous source for recharging the battery.
I’m just not sure why the utility power triggered the alarm and why it didn’t provide power to the freezer.
I'm considering changing the setup to act more as a UPS for the freezer but not sure how best to do that. Any advice would be appreciated!
