Hi all, I’m new here from remote Australian desert location.
newbie setting up the power star w7 (24volt) 6000w fed from two 12volt Lfpo4 300amp rating by voltax.
using a new EPEVER tracer 10420AN charge controller.
epever ebox BLE01 connected also.
So to get things started I have connected only two (of 10 mounted on roof) Trina solar TSM- 390DE09.08 panels 390 watt 11.54amps and 40.8 OCV.
Trying to use the EPEVER app but frustrated as the latest app info dated 2019 on their website and I simply want my system to recognise lithium batteries within the Bluetooth app that always reverts to sealed and auto voltage setting parameters .
the parameters being shown on screen appear to be simply double the 12 volt sealed lead acid and trying to use the READ buttons to accept changes is not changing things. Worried about charging lithium on sealed settings an sure I’m probably not the first to stuff things up.
Trying to remember what will prowse said about discharging the batteries before use and then charging them to 100% before live use.
this morning I loaded them up and discharged to zero through the inverter into various power tools.
However, way out here I do not have powergrid access.
So am charging using the 40kva diesel generator to provide ”shore”power through the Powerstar inverter and the two pv panels outputting 10>20 amps variously but wondering if this is correct method in circumstances or causing detrimental effects to the new system .
Oh and the app does not recognise the power star W7 so I am not seeing LOAD displays on the 10420 lcd either.
Batteries now (4:32 GMT) but 3pm local summer time here, appear from reading 10420 lcd to be fully charged (after 1.2 hrs) on generating power.
Feel free to admonish my failings and offer some guidance on any or all of the above before I connect another 4 panels.
The 10420 can only have 2500watt input i understand and my panels are parallel connected
cheers from Michael in sunny Australia
