❶Efficient Power Generation: Powland 3000W hybrid solar charge inverter applied the latest optimized MPPT technology to quickly track the max power point of the PV array in any environment and obtain the max. energy of the solar panel in real-time, maximum efficiency up to 99%. Pure Sine Wave, high safety performance could protect home circuit!
❷Important Specification: Employed advanced SPWM technology and outputs pure sine wave to convert 24V DC to 110V-120V AC, 50Hz/60Hz frequency (Auto detection). Max PV open circuit voltage range 100 Vdc; PV operating voltage range 30-100 Vdc; MPPT voltage range 30-85Vdc; Max 1600W input; Max 1400W output; Fit for24V Lead-Acid (seal, AGM, Gel, Flooded) and Lithium battery.
❸Multiple Working Modes:4 charging mode - Only Solar, Mains Priority, Solar Priority and Mains & Solar hybrid charging; 2 output mode - mains bypass and inverter output. The Inverter is designed with a LCD screen and 3 LED indicators for dynamic display of system data and operating status.
❹Safe and Reliable: The power inverter has 360°all-round protection with a number of protection functions, including short circuit protection, over voltage and under voltage protection, overload protection, reverse protection, etc. Ideal for AC loads such as household appliances, power tools, industrial equipment, and electronic audio and video equipment.
❺WE GOT YOU BACK: Note that the off-grid inverter can work only when the solar panel and the battery are connected at the same time. 12 months of hassle-free warranty and lifetime technical support. Contact us anytime with any questions.
