Pre-Charge Switch
Use this to keep it from turning until your momentary button is pressed but then allow it to be turned off quickly without having to do any extra steps.
That is an interesting idea for a 12V system. If the pushbutton both precharged and activated the bolt it would work well. The two downsides is figuring out how to mount the bolt and the esthetics.
A quick hint about amazon.com URLs : Everything from the /ref= to the end is just tracking info and is not really needed. The above URL can be shortened to this:
https://www.amazon.com/Atoplee-Electric-Assembly-Solenoid-27X29X18mm/dp/B0125VGLT0
If you want to shorten it further you can take out the text description and end up with this:
https://www.amazon.com/dp/B0125VGLT0
(I like leaving the text description)
You could even use a solenoid with a timed delay to block the main switch from being turned until the momentary was held down for X seconds or whatever, giving the caps time to charge up.
If you keep the charge resistance small, a delay would not really be needed.
I just found this switch:
Edit Updated images
It could be used for precharge like this:
Edit: This switch is only rated for 32 volts.
I am looking for clarification about precharge circuits.
Most solutions recommend a "manual" delay or with a relay.
What is the problem with an on-off circuit: a resistor bridging the relay contacts, isolation switches or BMS fet (with a 0-I switch that allows the circuit to be shut down for maintenance)?
-After the main circuit is switched on, by the relay, switch or fet, there is hardly any current flowing through the preload circuit! But by leaving it in service, wouldn't we protect the main contacts from the induction choke effect of an untimely cut-off, while benefiting from the precharge?
Two birds with one stone.
Thanks for the answers.
Edit Updated images
View attachment 87451View attachment 87472
Blue Sea 48V are also not rated for over 48V. You need a 60V rated switch. Put a resister and momentary switch in parallel. Press the momentary switch until the caps in the inverter charge, then switch on the main switch. About $4 in parts. I think some of the BMS's are now including a precharge circuit.
It's best to not post the same question in multiple threads. A dialog will start on one of them, then on the other, and.... Well, it's better to have people respond in one place.
I just want you to be aware of the limitations of many switches. ;)
The linked product is NOT designed to be switched OFF while carrying ANY CURRENT.
Instructions PDF can be found via this page: bluesea.com/products/5511e
• Turn all appliances off before turning the battery switch to OFF.
• Do not switch to OFF while engine is running.
Excuse the lack of label,
But blogs are still like discovering the butter thread ...
You go completely in the direction of the second part of my question!
Now if the installation has to face an emergency cut ???
Um, ok. I have no idea what that means.
It is an old French expression describing "genius" which reinvents or rediscovers the butter cutting!
In remote times, we sold the butter to detail from large clods ~ 10 kg and to detail it,
it was easier to cut it with a steel wire stretched between two pieces of wood that we heldby hands.
A tool so elementary that only a person whose mother had rocked him too close to the walls could glorify it!
Hence the expression: reinvent the butter cutting ...
CQFD
CQFD
Oh, ok. Thanks for the explanation.
However: Please don't post the same question in multiple threads.
CQFD
The butter cut wire
translator problem
Filter Guy
Quick question, I am building you're pre charge switch, what gauge wire do you use inside the switch? Looks like 10?
I am working on one and planning on using 10 AWG or 12 AWG I have lying around, but that wire looks much thicker than the resistor leads.
I can solder or crimp a butt splice for the resistor to wire connection and I have 3/8” ring terminals to crimp to my switch.
This is the pic of the 25 ohm 30 watt wire wound resistor I’m using
The leads are supposed to be 2 mm wide, which is supposed to be between 12 and 13, but it looks less.
Filter Guy
I think I used 10AWG because that is what I had lying around. You could use much smaller. I picked the resistor sizes for around 2 Amp at the battery voltage, and that will only be for an instant. You could get away with 16 AWG or even smaller.
I'm resuming this post because I'd like to build something similar, but I can't find the Perko and Mariner in Europe, and shipping costs from the US are too expensive. The Blue Seas 1+2 version is currently on sale on amazon for 40euro, so I was thinking of getting that.
@chrisski di you end up finishing your build? Is it working well? Curious to know your opinion.
