You're really grasping Tim. It's not the wiring around the light, it's not the light, it's not the house wiring.
The
" glowing led light with the switch off" occurred when I removed the N-G bond I had added in the loads panel as a test to see if indeed it is a bonding circuit problem.
Watch the videos again in this post.
https://diysolarforum.com/threads/problems-with-eg4-6500ex-buyer-beware.54597/post-793269
Been thru all of it since March. Very methodical, it's not the wiring. It is the 6500EX inverters. Installing the LV6548's eliminated the problems.
Signature Solar might have a pair of heavily discounted inverters you can purchase. They can simply put your name and address on the RMA call tag when these are picked up. It will be an educational experience for you.
