User settings from the suggested video have been applied to my newly installed system but the battery icon on MT50 are not matching up with actual charge in batteries???
User settings from the suggested video have been applied to my newly installed system but the battery icon on MT50 are not matching up with actual charge in batteries???View attachment 1135
I found the battery icon on the mt50 is pretty inaccurate also. If you really want the real stats on your system what I did was purchased the Aili battery monitor with the 350amp shunt from Amazon. It is $43 or a little cheaper with a smaller shunt. Bigger leaves room for system upgrades.
It does everything the Victron does but Bluetooth. Victron is $200. Meter allows you to set your battery capacity. Pretty easy install and set up. Pretty accurate.
Will has a video about this titled,
$200 Victron solar battery monitor?
Try this $30 Chinese one instead.
